1993 Ford Tempo 4 cyl
My 93 Ford Tempo overheated so I had a friend look at it and replaced the heater hose. It still overheated so they said it was the head gasket. Which he then replaced also. The problem continued so I then replaced the anti-freeze, had the spark plugs and thermostat fixed, which solved the heater problem but the car is still running hot. I had a second opinion and they then said that some rings needed to be replaced in the engine because of the oil line now. Which the engine would have to be taken out and put on a machine and it would cost at least $800? Can you please assist me with this problem and are they correct?
Wednesday, December 9th, 2009 AT 12:09 PM
