1993 Ford Tempo check engine
DRENEAU
Engine Performance problem
1993 Ford Tempo 4 cyl Two Wheel Drive Automatic
car sometmes stalls when slowing down to stop at a light or for traffic. it always restarts. this is intermitent also the check engine light on and off intermitent
Oct 15, 2010 at 12:20 PM
BMRFIXIT
  • 19,053 POSTS
Check for any vacuum leaks
remove and clean or replace idle air control valve
check for codes
Oct 15, 2010 at 12:38 PM
FIXITMR
  • 9,989 POSTS
when was last tuneup? weak coil wire can trigger stalls. another typical problem for these cars is IAC valve malfunction. it controls idle speed. check also for any bad vacuum hoses. putting on brakes uses engine vacuum to operate brake booster. the sudden large draw can effect engine speed. getting CE codes read could help also.
Oct 15, 2010 at 1:05 PM
