1993 Ford Tempo car making loud moaning noise at air intake
1993 FORD TEMPO
16,100 MILES • 4 CYL • 2WD • AUTOMATIC
MIKE PETT
Car starts fine runs a couple of minutes and begins idiling rough and makes a moaming noise at air intake, also when engine is shut off it makes loud moaning noise.
Jul 17, 2009 at 12:28 AM
RACEFAN966
  • 5,029 POSTS
I would like you to check the idle air control motor and see if the noise is coming from there. Here is a pic of it and you can use a long screwdriver or automotive stethiscope and to listen to it. If you use a long screwdriver just put the handle end to your ear and the other on the Idle Air Control Motor. Here is the pic and let me know how it goes.
https://images.2carpros.com/forum/automotive_pictures/249564_93807_1.jpg
Jul 17, 2009 at 2:04 AM
DOCFIXIT
  • 18,828 POSTS
Hi
On the intake manifold right side just past throttle see the air by-pass valve. is nois comming from that area? What condition is air filter?
Let me know
Thanks for donate
Jul 17, 2009 at 2:12 AM
MIKE PETT
To racefan966.
Thanks for the help. I tried the screwdriver and could not pinpoint the noise. I went to a junk yard found an idle control motor ( found a new one that had recently been replaced on old junker) paid the yard $10.00 works perfect. donated small amount to you guys. Total time about one hour. Went and bought case of beer, drank a big toast to you guys.
Thanks to you i have the rest of the weekend to play.
I will definately recommend your service to everybody I can.
Thanks again guys and have yourself a good weekend.
You guys rock!!!!
Jul 17, 2009 at 7:50 AM
RACEFAN966
  • 5,029 POSTS
Thanks for the update. Glad it is working as it should again. Have a great weekend.
Jul 18, 2009 at 2:22 AM
