it will go in reverse and nutruel but when in drive it wont shift out of first gear
Jan 12, 2010 at 11:01 AM
DANDENISE
MEMBER
im not sure on this transmission but check and see if there is any vacuum lines that run to your trans if there is make sure none are broke or leaking if there arnt any let me no and ill walk you through how to fix it
dan
