1992 Ford Tempo where is the fuel pump
167,000 MILES • 4 CYL • 2WD • AUTOMATIC
FIRELADY
I experianced lack of power during exclleration up a hill. Turned around went home but it was WAY sluggish. Could not go over 35. Got home. Can this be the fuel pump? Where is it to replace?
Thank you,
Janell
Mar 28, 2008 at 6:27 AM
MERLIN2021
  • 17,250 POSTS
Fuel pump is in the gas tank...have the pressure tested, it can be other things, like clogged converter, or timing is off a tooth or two...
Mar 28, 2008 at 6:30 AM
