1992 Ford Tempo water leaking
THERESA THOMAS
Air Conditioning problem
1992 Ford Tempo 4 cyl Automatic 165000 miles
water leaks inside while using air coditioner
Sep 24, 2010 at 3:35 PM
FIXITMR
  • 9,989 POSTS
you mean water not antifreeze? the drain is plugged/malfunctioning or your plastic casing has a leak. will look tomorrow to where drain hose is located. should be on pass side on firewall under hood. may not be easy to get too.
Sep 24, 2010 at 5:21 PM
