1992 Ford Tempo Trying to replace the starter
19,200 MILES • 4 CYL • FWD • AUTOMATIC
JENATELLO
I am trying to replace the starter on my boyfriends Ford Tempo. The problem I am having is that there is a piece of metal welded to the car that is blocking me from getting to the nuts and bolts of the starter to remove it. This wouldn't normally be a problem but the person how owned the car before we did tightened the bolts so tight that I can't loosen them with an open wrench and I have no idea what I should do to get it off. The piece of metal is on the bolt in front of the nuts that are holding the starter in place, with more nuts holding the metal to the bolts. I got the first set of nuts off and the metal will not budge.
I know for a fact that it's the starter and am tired of having to drive my boyfriend around. Please help me!
Jul 11, 2008 at 8:58 AM
OBLIO88
[quote="Jenatello"]Engine Performance problem
1992 Ford Tempo 4 cyl Front Wheel Drive Automatic 192,00 miles
I'm trying to do the same thing for my son's 1993 Tempo. On this car, it looks like the metal bracket is attached to some components of the exhaust gas recirculation system. It's unwieldy, but I think I have to disconnect the hoses so I can get the bracket and pipes it's welded to off of the car. Hope you haven't been waiting a month for the answer.
Aug 7, 2008 at 11:29 AM
