1992 Ford Tempo please help
82,222 MILES • 4 CYL • FWD • AUTOMATIC
AMBERROTH
My shakes when I get to a set speed and when I push on the gas it stops and when I try to start it it only clicks.
Jul 3, 2010 at 6:09 PM
DAVE H
  • 13,383 POSTS
have the wheels balanced .. check the battery and alternator are good also the starter motor abd wiring
Jul 3, 2010 at 11:40 PM
FIXITMR
  • 9,989 POSTS
clicking indicates bad connections or or bad parts. check battery posts first. remove and clean and reattach. if that dont work, check starter connections. if that dont work you may have bad starter brushes. yap on starter with hammer while trying to start. if it makes it go you have bad brushes. if that dont work you may have bad starter relay which is on inner fender under hood follow red wire from battery to it. cross large bolts/posts with scewdriver. if that makes starter work replace relay. to complicate matters, you may have a second relay on starter itself? some models did!
Jul 7, 2010 at 7:54 PM
