1992 Ford Tempo new lines
JONDAWG44601
Brakes problem
1992 Ford Tempo 4 cyl Front Wheel Drive Automatic 260K miles
I have just installed new rear brake lines from the master cylinder to the rear wheels. i was just wondering if there is some sort of a splitter device or something located somewhere in the front of the car, in the frame because now when I attempt to bleed the brakes, I have brake fluid pouring out of the frame area right behind the drivers side tire.
Jan 25, 2009 at 6:15 AM
FIXITMR
  • 9,989 POSTS
sounds like you missed something when you did replacement.especially if you used old information/previously memorized procedure.not all brake line systems are identical.or fixing 1 thing broke another.also replacing line next to another can cause crack in line not being replaced from disturbance.old lines if they have a rust spot can be fragile.inspect leak closely and find source.
Feb 13, 2009 at 12:05 PM
