1992 Ford Tempo help me
KENJOSLYN
  • 1992 FORD TEMPO
Transmission problem
1992 Ford Tempo 4 cyl Front Wheel Drive Automatic
when I put my car in to any gear its like its in neutral. Park is like park but any other gear is like neutral. Whats the problem?
Sunday, February 21st, 2010 AT 5:20 PM
FIXITMR
  • 9,990 POSTS
Did you check the level of the transmission fluid? Dipstick is down beside battery between radiator and engine. Sorta difficult to get to. But not impossible. You need to check it while engine is running. When engine is off it will/should read OVERFULL. When did this problem start? Was it sudden?
Monday, February 22nd, 2010 AT 12:47 PM
