1992 Ford Tempo Heater
RFAIR
Heater problem
1992 Ford Tempo 4 cyl Wheel Drive Type unknown Automatic 175000 miles
My heater will not blow hot air. I had the thermostat changed but it still blows air that's not cold, but more room temprature.
Jan 4, 2008 at 4:29 AM
ANTHEMBASSMAN
  • 16 POSTS
-Sounds like the cable from the dash has come diconnected from the lever. Get a flashlight and lay on the floor. Shine the light up behind the dash while moving the lever back and forth. You should see it moving and also it should be connected to a small metal rod.
Matt D.
Jan 12, 2008 at 5:15 AM
