1992 Ford Tempo Heater
RFAIR
  • 1992 FORD TEMPO
Heater problem
1992 Ford Tempo 4 cyl Wheel Drive Type unknown Automatic 175000 miles
My heater will not blow hot air. I had the thermostat changed but it still blows air that's not cold, but more room temprature.
Friday, January 4th, 2008 AT 12:29 PM
ANTHEMBASSMAN
  • 16 POSTS
-Sounds like the cable from the dash has come diconnected from the lever. Get a flashlight and lay on the floor. Shine the light up behind the dash while moving the lever back and forth. You should see it moving and also it should be connected to a small metal rod.
Matt D.
Saturday, January 12th, 2008 AT 1:15 PM
