1992 Ford Tempo Harmonic Balancer
RGRAH
Engine problem
1992 Ford Tempo 4 cyl Front Wheel Drive Automatic 130 km miles
I suspect that the harmonic balancer is broken on the car. I looked up some information and there is no
easy way of finding out how to remove the harmonic balancer. I would really appreciate any information on
how to remove it without taking a long time if possible.
Feb 3, 2008 at 2:17 PM
ANTHEMBASSMAN
  • 16 POSTS
-You're out of luck here. It is kind of a long process that involves jacking the car up on jack stands and dropping the motor far enough to access the mounting nut and getting the balancer out. I did it with my car and it took a couple hours or so to get it replaced. Anything you read about changing it is pretty much the way it is. You can't really shortcut any steps with this one.
L8R,
Matt D
Feb 9, 2008 at 1:22 AM
