1992 Ford Tempo front tie rods
90,000 MILES • 6 CYL • FWD • AUTOMATIC
ANGELA32724
i need to know what it should cost to have the front tie rods replaced. i am told that the bushings or rubber mounts at the end of the rods are not replaceable and i would need to replace the entire rod and ball joints? is this true and if so is it a big job? i need help i have been given outrageous repair price for this job and the car isn't even worth that much, can you help?
Aug 14, 2009 at 3:33 PM
BMRFIXIT
  • 19,053 POSTS
An outer tie rod end should be about $ 75 to replace
need to have to do an alignment after its $55 to $70 to do
Aug 15, 2009 at 11:41 AM
FIXITMR
  • 9,989 POSTS
by your description it sounds like lower control arms instead of tie rods or maybe BOTH? yah, these tempos are KNOWN for this stuff! american quality at it's finest? the bushings can be replaced with a homade one. i made one out of a cross section of airconditioning hose!
Aug 17, 2009 at 8:14 AM
