1992 Ford Tempo door locks
227,135 MILES • 6 CYL • FWD • AUTOMATIC
FONZAROO
this has been this way for years but i'm curious to see if it's a simple problem or not. auto door locks use to lock all 4 doors. then a few years ago the drivers door stopped unlo9cking. I have to do this with a key. then the back passanger door, kitty cornor to the drivers stopped unlocking. Not sure but does a fuse 23a ring a bell to anyone. I read somewhere this or maybe it was a 30a is the fuse i need for the problem. in where the fuses go, it's big and silver. does this sound like a fuse problem or something bigger?
Feb 25, 2009 at 2:21 PM
FIXITMR
  • 9,989 POSTS
sounds like the lock motors are fried.tempo's(fords) are notorious for this.after all,the car is old?pop panel and they are riveted in.drill chisel rivets or work loose from rubber/nylon mount and replace.i get mine form boneyard and have tested before i buy.i think they use the same motor in several types of fords?
Feb 27, 2009 at 2:10 PM
