1992 Ford Tempo car wont go into gear
GENNI
Engine Mechanical problem
1992 Ford Tempo 4 cyl Front Wheel Drive Automatic unknow miles
A couple of days prior, a brake light, like when you pull the Emergency brake, illuminated on the dash it had parenthesis( )around it, I think it was (B) and then the engine light goes on when clinbing hills but the temperature never rises into the red or past the R on normal, now I started the motor and when I shift into R,D,1 or 2 the motor idle changes but the car will not move.Please advise I only paid $750.00 for the car but its all I have right now.
Aug 19, 2008 at 3:23 AM
  • 75,988 POSTS
Pull the code/s from the computer-there's a problem within the engine management system. For the transmission that refuses to move in gear-check the fluid level and condition-if okay you have an internal problem with the transmission.
Brake light on-check master cylinder fluid level-
Aug 19, 2008 at 7:13 AM
