1992 Ford Tempo Battery Drain
114,000 MILES • 4 CYL • 2WD • AUTOMATIC
PURCELL52
I pulled fuses until I found the circuit that was causing the drain.It was the fused that ran the radio, power mirrors, dome lights under hood light switch & decklid switch. I unplugged every switch & connector in the circuit, but it was still causing a drain. What else is their that I can check?
Jan 1, 2008 at 6:41 AM
  • 75,988 POSTS
Since its not the load itself-therefore the wire has a direct short to ground. Put the fuse back in-disconnect the alternator wiring all of it and see what happens if the drain goes away-you have a shorted diodes in the alternator.
Jan 1, 2008 at 6:49 AM
PURCELL52
[quote:1420414fe5="rasmataz"]Since its not the load itself-therefore the wire has a direct short to ground. Put the fuse back in-disconnect the alternator wiring all of it and see what happens if the drain goes away-you have a shorted diodes in the alternator.[/quote:1420414fe5]
I did this & I still have a drain
Jan 1, 2008 at 7:20 AM
