Engine Mechanical problem
1992 Ford Tempo 4 cyl Front Wheel Drive Automatic
car stalls out frequently
Thursday, June 11th, 2009 AT 2:28 PM
FIXITMR
MECHANIC
Does it start right back up? Is it a good runnnig car? When was the last tuneup done? Check the coil wire ends internally for corrosion! Look inside the boots on each end! If the coil end is bad it can short out the coil!/Spark, thus stalling car!
