Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Tempo
Drivetrain
Transmission
Fluid
1991 Ford Tempo transmission linkage
1991 FORD TEMPO
175,000 MILES • 4 CYL • FWD • AUTOMATIC
CAMO18
MEMBER
1 POST
thank you for your answer!
trans fluid is full
and car does push in nuetral
so.....
Apr 26, 2009 at 8:29 AM
FIXITMR
Experienced Mechanic
try to push car with shifter in neutral. if it moves the linkage is working. then check trans fluid level.
Apr 27, 2009 at 11:33 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
