1991 Ford Tempo Starting and running
1991 FORD TEMPO
150,000 MILES • 4 CYL • 2WD • MANUAL
BULLDOG965
Tempo has new alternator and new battery. The old alt tested at only 7 amps so it was replaced. Car ran good for a few days but died again and the amp light came on. Car can be boosted off and will run a while then shut down electrically, * dim lights then radio dies etc* Also, now for some reason when you step on the brake the radio quits.
Nov 15, 2009 at 9:51 AM
FIXITMR
  • 9,990 POSTS
boost and get car started. check voltage at battery posts. should be 14 to 15 volts. if 12 or lower volts your alternator is not charging battery. have it tested again. also sounds like a wiring or connection problem somewhere. maybe your battery ground to body/frame is corroded/disconnected.
Nov 18, 2009 at 3:14 PM
