1991 Ford Tempo stalls with out gas
TAMARANO07
  • 1991 FORD TEMPO
  • 4 CYL
  • FWD
  • 150,000 MILES
The referenced vehicle above will stall when I stop feeding it gas. It will stall, unless I keep my foot on the gas while breaking. To start it I have to feed it gas, then keep feeding it gas for about 5 minutes before I try to change gears otherwise it stalls out and I can't start it again for another 10 minutes. If I slow to go around a courner it will stall, sometimes it will start right back up again, but most times it doesnt, and I have to sit there feeding it gas trying to start it.
Replaced spark plugs and wires, gave it a gas treatment, replaced fuel filter, checked fuel injector.
i've put enought money into this car and would like it last a little longer!
Thank you
Sunday, January 24th, 2010 AT 6:51 PM
FIXITMR
  • 9,990 POSTS
What soot color were the old plugs?
Blackish-brownish-whitish?Should be a brownish /tan color. Look at 1 of the 1's you just put in. Also you might have a vacuum leak check all hoses from intake for leaks/cracks broke/undone. The next major culprit is the IAC valve ( idle air control) located behind and on side of throttle plate assembly. Tube shaped with plug on bottom. The usual complaint with these is FAST idle. So it's probably not it! You could remove it to clean it thoroughly though. If your plugs are whitish your running to lean and that can cause stalling and poor performance.
Sunday, January 31st, 2010 AT 11:01 PM
