1991 Ford Tempo Speed control not working
ZINC03GT
Electrical problem
1991 Ford Tempo 4 cyl Front Wheel Drive Automatic
was working a few months ago now it doesn't. Checkead all vacuum lines and they appear to be ok. There is power at the wiring harness connector.
May 12, 2008 at 9:55 AM
MERLIN2021
  • 17,250 POSTS
Try unplugging the deactivator switch at the master ctlinder, jump the two leads with a piece of wire, and go for a spin..
May 12, 2008 at 10:36 AM
ZINC03GT
[quote:274c3e2285="merlin2021"]Try unplugging the deactivator switch at the master ctlinder, jump the two leads with a piece of wire, and go for a spin..[/quote:274c3e2285]
Where exactly is this "deactivator switch" ?
May 12, 2008 at 6:53 PM
MERLIN2021
  • 17,250 POSTS
Look on the master, if it has one it's a two wire connector, and the switch screws into the master...
May 13, 2008 at 8:47 AM
