1991 Ford Tempo
1991 FORD TEMPO
RICKYSTATON
1991 Ford Tempo
where is the ignition modual located
Mar 21, 2009 at 1:06 AM
FIXITMR
  • 9,990 POSTS
should be right on the bottom/side of distributor right in front between engine and radiator.it's difficult to remove cause it may require a special socket/tool.the tiny bolts are at the bottom of long narrow holes in the plastic.i use a 7/32 deep 1/4 drive socket that i ground end smaller by chucking in my drill and spinning against grinder.
Mar 21, 2009 at 7:37 AM
