1990 Ford Tempo right front wheel is more or less, not movi
130,000 MILES • 4 CYL • FWD • MANUAL
CHRIS2009TAYLOR
  • 26 POSTS
My right front wheel is hot to touch, and I suspect the brakes or the bearing on this side. I don't hear any rumbling; so I think it is the brakes.I've therefore taken off the front wheels(1990 ford Tempo - regular, is on front jack stands)and put it in gear: the wheel seems to turn freely.
Any suggestions? Why is the right side seemingly seized (pulling) - I can only travel about 45 km/hr top speed... everything was fine the week before.
Oct 8, 2009 at 2:38 PM
JEEPFAN
  • 135 POSTS
sounds to me as though your brake caliper is sticking
Oct 8, 2009 at 3:04 PM
FIXITMR
  • 9,989 POSTS
you can remove pads and pump out the caliper piston till the rubber bootseal is easy to pry/lift away from piston. see if rust/dust is visible and try lubing behind/under seal with a rust dissolver like WD40 or just use brake fluid. use clamp to work piston back in. if too much resistance is found then maybe rubber brake hose is internally blocked/collapsed. loosen bolt holding it to caliper and see if piston moves easier. if so, remove hose and test by having pedal pushed to see if fluid flows freely and easily.i f not replace hose/bleed caliper reassemble and do drive test.
Oct 9, 2009 at 3:56 PM
CHRIS2009TAYLOR
  • 26 POSTS
calipers will be replaced. I had decided this before asking the question, but was wondering if the heat being generated could be from anthing else , before going ahead. Thanks for the comments, and I will let you know if this solves the problem.
The disc appears to be ok, ie not warped... but their is some discoloration... Is this a problem? disc needs replacing?
Thanks for the comments, as it turns out as suspected it was the Calipers.
I was concerned with the slight discoloration of the Disks, but I clean them up and they seem to be working fine!
Thanks to all those who submitted comments(jeepfan and fixitmr). I don't know how these points work? How do I get points? How many points to give if comment was helpful? I gave point to the fellow that was first to suggest it was probably the calipers.
Thanks again,
Chris
Oct 10, 2009 at 5:08 AM
