1990 Ford Tempo- leaking water/coolant...
1990 FORD TEMPO
MPIPPIN
1990 Ford Tempo: water leaking....
water pump has been replaced but there is still water leaking from under motor somewhere.. what else might it be?? I cant see where it is coming from. It is in the vicinity of the water pump/passenger side area.
Jul 17, 2010 at 11:33 AM
FIXITMR
  • 9,990 POSTS
you might have a bad soft plug in the block in that area. or 1 of the water lines is leaking. some are metal and can develop rust holes. usually where there is a weld or bracket.
Jul 25, 2010 at 12:58 AM
