1990 Ford Tempo Ignition Switch
RAYRAY1984
1990 Ford Tempo 6 cyl Front Wheel Drive
Can you tell me step by step how to replace the ignition switch on 1990 Ford Tempo? Im stuck on trying to get the panel loose below the dash to let the colum drop so i can reach the bolts on the igition switch...Thanks
Sep 10, 2009 at 8:52 AM
FIXITMR
  • 9,989 POSTS
is the panel bolted or riveted? i cant remember! sounds like your doin just fine! keep goin! if ya run into a real problem, come back!
Sep 10, 2009 at 2:53 PM
