1989 Ford Tempo coolant termperature
250,000 MILES • 4 CYL • 2WD • MANUAL
GUNTERK
1989 Ford Tempo. Coolant reads about 1/4 of full range when at normal operating temperature. Is this normal, or is this running too cool? What are the consequences of running too cool?
Thanks in advance
Jan 9, 2010 at 8:11 AM
FIXITMR
  • 9,989 POSTS
there's really no penalty for running to cool!? other than the heater is not hot enough for you or it may cause an emitions test fail to pass.
Feb 7, 2010 at 12:26 PM
GUNTERK
thank you, Fixitmr. I will leave it alone then.
Feb 7, 2010 at 1:16 PM
FIXITMR
  • 9,989 POSTS
the other thing i would mention is that your low reading can be caused by the sensor,the gauge itself,or a weakening thermostat.
Feb 7, 2010 at 2:20 PM
