1989 Ford Tempo car wont run
130,000 MILES • 4 CYL • FWD • AUTOMATIC
TERRY BARRETT
the engine will not run, I am getting gas threw to the fuel filter ,if I spray fuel in the intake it runs , when I stop spraying the fuel it stops. I have changed the fuel pump ( I thought the fuel pressure may be low in the old pump , but it still wont run. the car has been sitting 2 years and I want to get it running to sell it
Thank You
terry Barrett
Mar 7, 2010 at 9:39 AM
  • 75,988 POSTS
Check the fuel pressure with a fuel pressure gauge if it's within specs.-also are the injectors pulsing?
Mar 7, 2010 at 5:14 PM
