1988 Ford Tempo valve cover...
1988 FORD TEMPO
138,000 MILES • 4 CYL • FWD • AUTOMATIC
RANDY07
I bought a 88 ford tempo automatic, and i changed the valve cover gasket from a oil leak but now there is pressure going through the valve cover and light smoke. i have had it looked at and they say its the piston rings are stuck and some say its compression rings in the engine but they just looked and saw what it was doing and guesstimated what it was.
Mar 18, 2010 at 1:44 PM
TOOOMANYTOYS
  • 513 POSTS
Check to see if the pcv valve is sticking. It may just need a new valve. I its ok you might want to do a compression test to see if your rings are seating good.
Mar 18, 2010 at 1:52 PM
