1988 Ford Tempo INTERCHANGEABLE PARTS
COORADOPEACH
1988 Ford Tempo 4 cyl Two Wheel Drive Automatic
i WOULD LIKE TO KNOW IF THE PARTS BETWEEN A 1988 AND 1991 FORD TEMPO GL ARE INTERCHANGEABLE
Jan 16, 2009 at 12:03 PM
FIXITMR
  • 9,989 POSTS
should be.generally speaking.even some escort parts interchange.especially mechanical parts.but electrical is more iffy.especially with the motor electrical.for instance some tempos' came with different starters/alternators.they are still interchangable if you know how to rig.the alternators need wring rerouting as plugs dont match.the starters also need some wiring changes to go from small style to large style starter or vice versa.generally speaking the farther apart the years the more differences you can encounter.also canadian made tempo's may have different electrical parts like ignition parts.general rule is if part looks the same it is.
Jan 31, 2009 at 4:21 AM
