1988 Ford Tempo How to remove a headlight lens on a 1988 Fo
52,000 MILES • 4 CYL • FWD • AUTOMATIC
RSAMINAL856
i am inquiring on how to remove the lens from a headlight on a 1988 Ford Tempo.Thank You.
Jun 6, 2009 at 3:36 AM
FIXITMR
  • 9,989 POSTS
not sure about your question? whats the reason for removing lens? do you mean headlight lens/reflector assembly?according to Haynes it is held in by 4 nuts from behind. an upper and lower on each side.
Jun 6, 2009 at 6:48 AM
RSAMINAL856
to renew the faded lenses for better visibility
Sep 12, 2009 at 6:42 AM
FIXITMR
  • 9,989 POSTS
ok, i know exactly what you mean now. i use a headlight polishing compound to make them clear again. you can get it at the local auto store. but if your chrome reflecting material on the inside is ruined then you can look for better light assemblys at the scrap yard! maybe you can even buy new 1's online somewhere? do a google search!
Sep 12, 2009 at 4:46 PM
