1988 Ford Tempo
CHRS
  • 1988 FORD TEMPO
Shakes or Wobbles problem
1988 Ford Tempo Two Wheel Drive Automatic
I have a 88 Ford Tempo 2.3. In moring whem cold it idles fast like it should but after warming up it idles to slow and rough. When ac is turned on it idles up like it should also when cooling fan comes on but then slows down and idles to slow and rough. After motor is hot and stop for light it idles good for a few seconds and then to slow and rough. Ford dealership and others can not find problem. The vacum is ok valve and timing and etc. I swaped all sensors from another car did not help. I changed Idle Air control. I have hand held checker and it shows all systems ok. Dealership had larger computer.
Thank You
Chris Bassett
Sunday, July 13th, 2008 AT 8:15 PM
2CARPRO JACK
  • 11,533 POSTS
Check the motor mounts. Maybe since no one can find anything wrong with the engine it is just a case of collapsed mounts causing you to feel more vibration at lower engine speeds. Does the car die or just feel rough?
Monday, July 14th, 2008 AT 7:34 AM
