A strange one?I assume fluid level is normal(check while running/parked). The trans has no electrical internal parts to fail hot so all that's left is the kickdown mechanism which is rod from throttle down to arm on trans by shift cable mechanism. It can become disconnected and cause shift problems or it's set wrong(adjustable). If this dont help, keep trying to refine the problem/symptoms.
SPONSORED LINKS
Friday, February 13th, 2009 AT 3:35 PM
