1986 Ford Tempo loose steering
SPANKY10
Steering problem
1986 Ford Tempo Two Wheel Drive Automatic 100000 miles
steering wheel has recently become loose,took column apart but cannot find a way to tighten it
Jun 9, 2009 at 11:46 PM
FIXITMR
  • 9,989 POSTS
you got an old one there! i just took apart an 88-89 and it was quite easy! that is if we are talking TILT WHEEL!a couple bolts to tighten up! they are pointing right and left when you are behind the wheel! if it's NOT tilt wheel then it's probably bearing related? are you just saying the steering WHEEL is wobbly and not the actual car behavior?
Jun 11, 2009 at 3:18 PM
SPANKY10
yes it is a tilt steering wheel,thank you for your help
Jun 12, 2009 at 12:31 AM
