1985 Ford Tempo Won't start
63,000 MILES • 4 CYL • FWD • AUTOMATIC
WKL78
Hi. The car won't start unless I spray starter fluid in the air cleaner. After that it starts and runs fine. If I turn it off it will restart for about 30 minutes, after that I have to spray the starter fluid again. The battery is one year old.
Jul 13, 2010 at 6:52 AM
  • 75,988 POSTS
When you turn key On do you normally hear the fuel pump come on? if it comes and go test the fuel pump relay to include the fuel pressure
Jul 13, 2010 at 7:42 AM
