1985 Ford Tempo Engine will not turn off at ignition switch
225,000 MILES • 6 CYL • 2WD • AUTOMATIC
POOHBEAR2U
I had to have my truck worked on to pass smog and ever since then when you turn the ingnition switch the guages trun off but not the engne. I replaced the ignition switch but it didn't make any difference. It does not do this when the truck is cold only after it has been run awhile.
Jan 30, 2009 at 8:48 AM
  • 75,988 POSTS
Something causing the throttle plate not to close completely and its dieseling/Run on
Jan 30, 2009 at 8:54 AM
