Thank you for your patience.
This car acts like it isn't getting enough gas.
I start out in drive, get the car going about 20-25 and as it shifts into 2nd gear it stalls out. If I put it in low gear it does alittle better.
The plug wires, distributor cap, and a seal underneath the carberator were replaced yesterday. Now the car runs even worse.
I just found out that the gas tank has been damaged pretty bad, by someone backing over a stump. It doesn't leak, but would that have anything to do with the problem.
My mechanic I have had for years can't even figure this out. Also another mechanic that works for him.
Any suggestions are helpful. Thank you.
Saturday, February 21st, 2009 AT 2:00 PM
