1984 Ford Tempo
NITSUR
  • 1984 FORD TEMPO
Steering problem
1984 Ford Tempo 4 cyl Front Wheel Drive Manual
How do I replace the power steering pump. I cannot find what I am supposed to loosen in order to get the serpentine belt off
Monday, October 5th, 2009 AT 2:15 PM
FIXITMR
  • 9,990 POSTS
There is a tensioner pulley that is loosened by bolts or is springloaded and is moved by inserting ratchet bar in square hole and lifting. Then belt can be removed. Pump is a little more difficult on these if pump has pressed on pulley. You have to get special puller to take off to get to bolts for removal.
Friday, October 9th, 2009 AT 11:28 PM
