2002 Ford Taurus No Crank
At the starter solenoid find the small terminal S on it white and pink -now have someone hold key to start positiion -do you have power? if not check the TRS input power red and light blue coming from the Ig switch -do you have power-No power bad ignition switch.
Have a nice day
Suggested Repair
The starter itself is good because it cranks when battery power is applied directly to the solenoid. With start power present on the red/light-blue ignition feed but not at the solenoid, check continuity of that circuit. If the wire is open, repair it; if continuity is good, replace the transmission range switch.
Conversation Summary
A 2002 Ford Taurus SES with about 100,000 miles will not crank and makes no click. A new battery and starter relay did not help, and the lights do not dim, but the starter works when the solenoid is powered directly. Power is present on the red/light-blue start wire from the ignition switch, but not at the starter solenoid. The expert advised checking continuity of that wire and replacing the transmission range switch if the wire is intact.
