2003 Ford Taurus Won't Crank
CAPN212
I have 2003 Ford Taurus and the engine won't start. I started out about a week and a half ago having a little trouble cranking, then it worked fine for a while and then had a little more trouble, until eventually yesterday it just stopped. I've tried replacing the battery but still nothing. When it was having trouble before I still had radio/air/lights inside, and still do with the new battery. However it tries to turn over with a little clicking then just some groaning. My friends and I were thinking starter or alternator, but not sure which.
Thanks,
-Grant S
Sep 8, 2007 at 1:48 PM
  • 75,988 POSTS
[quote:ad6bfd8262="Capn212"]I have 2003 Ford Taurus and the engine won't start. I started out about a week and a half ago having a little trouble cranking, then it worked fine for a while and then had a little more trouble, until eventually yesterday it just stopped. I've tried replacing the battery but still nothing. When it was having trouble before I still had radio/air/lights inside, and still do with the new battery. However it tries to turn over with a little clicking then just some groaning. My friends and I were thinking starter or alternator, but not sure which.
Thanks,
-Grant S[/quote:ad6bfd8262]
Could be the starter but you have to rule out the ignition switch/NSS or TRS/starter relay your starting circuit goes thru these things before it gets to the starter.
Sep 8, 2007 at 2:06 PM
CAPN212
is there a way to check if its one of those without taking it in, or am i better off just assuming that I'm over my head and gettin it towed to the shop?
Sep 8, 2007 at 5:00 PM
  • 75,988 POSTS
[quote:d5681c4eb1="Capn212"]is there a way to check if its one of those without taking it in, or am i better off just assuming that I'm over my head and gettin it towed to the shop?[/quote:d5681c4eb1]
Best bet is to bring her in.
Sep 8, 2007 at 6:02 PM
Suggested Repair
Have the starting circuit diagnosed at a shop. Rule out the ignition switch, neutral safety or transmission range switch, and starter relay before replacing the starter.
Conversation Summary
The owner of a 2003 Ford Taurus reported progressive cranking trouble that ended in a no-start with clicking and groaning. A new battery did not help, though interior accessories still worked. The expert said the starter is possible but the ignition switch, NSS or TRS, and starter relay must be ruled out first, and recommended taking the vehicle to a shop.
