was told i have a moderate oil pan gasket leak
TORRIE
what am i looking at with this type of a problem. it's a 2003 ford taurus. I was told that there is a moderate oil pan gasket leak. What will i have to do or should do
Sep 7, 2007 at 3:07 AM
BLMO
  • 72 POSTS
You should start by getting a Haynes or Chilton manual (if you haven't done so already).
If you have a Y pipe (that huge Y-shaped exhaust pipe under the car), then you will need to remove it. It's not as easy as it seems, because there's a bolt that you can't see.
Once you get the Y pipe off, removing the oil pan is straightforward.
Sep 28, 2007 at 1:56 PM
