Vacuum Leak
PACECLASSA
  • 39 POSTS
1995 Taurus SHO, 3.0L, 6cyl, 122,000mis
High NOx levels on emissions. Checked, replaced or cleaned everything I could. My uncle says it is either a vacuum leak or the catalytic converter. Don't want to mess with the Catalytic Converter, but I can check for a vacuum leak. How do I do that?
Thanks
Aug 5, 2007 at 3:28 AM
BLMO
  • 72 POSTS
There are several ways. First, get yourself a vacuum gauge, and verify that the engine vacuum is good during low idle, when accelerating (just open the throttle while standing still), etc.
Another way is, if you suspect an intake manifold leak, put some soapy water around the base of the manifold (both upper and lower), and watch for bubbles.
Also, check the PCV hoses (my car has three of them, one of which is not visible with the naked eye - you just have to know it's there. I had to take off the upper plenum just to see it, but it was the problem).
If you still can't find a vacuum leak by sight, use a stethoscope.
Sep 25, 2007 at 11:46 PM
