Trouoble code PO430
THEMODELMP
I have a 97 ford taurus 3.0 V6 . I pulled the code PO430 from the data link connector and was wondering what part of the system it relates too if perhaps it is the O2 sensor bank 2 or what.
Oct 19, 2007 at 8:16 AM
THEMODELMP
[quote:f39273652c="themodelmp"]I have a 97 ford taurus 3.0 V6 . I pulled the code PO430 from the data link connector and was wondering what part of the system it relates too if perhaps it is the O2 sensor bank 2 or what.[/quote:f39273652c]
Oct 19, 2007 at 8:17 AM
TAURUSWHEEL
  • 718 POSTS
That code requires a series of tests which ultimately determine if the cat is bad, however you should check all the vacuum, electrical connections and so on first.. I have to check and get back with you, but I think a pal of mine had this code on his Lincoln, turned out to be something with the fuel system, wiring or some issue...
Oct 20, 2007 at 11:19 AM
