[quote:acac25caea="justanold"].....One electrical connector..one 13mm nut..two 8mm bolts. after replacing.. 8) 8) 8)
[/quote:acac25caea]
Justanold....Thanks much, you were right on the money...Right down to the socket size..... :) :) :D :D The hardest part of the repair ws getting off the electrical connector...I was not sure how to take it off....
I have a 97 taurus, 3.01 engine. The symtons were when in reverse, the radio quit playing ( or passing over revesre), the power steering did not function, and at time the power windows would not work, every once in a while I woudl hear a sound like a relay switch going back and forth. Once in Drive every thing worked. I let this go for a while, and the other night the car did not shift properly , it stayed in 1st gear (top out at 20 mph). I replaced the switch and everything was good to go..Now I have tunes when I back up, but I have to admit I did like it when it turn the radio off while backing up....nice safety feature...
THANKS AGAIN>>GREAT INFO :D :D
Nov 1, 2007 at 1:59 AM
