Tail lamp replacement 2005 Taurus
BODLE1956
2005 taurus 4dr se 3.0v6 60000mi need to replace the bulb
Nov 18, 2007 at 12:14 PM
TAURUSWHEEL
  • 718 POSTS
Not quite sure on yours, I know some earlier models you had to remove one nut, then snap the whole lens unit off the car, others had the lamp sockets buried behind misc trim pieces.. maybe pick up a Chilton's manual or something to refer to.
Nov 19, 2007 at 3:09 PM
BODLE1956
There are 5 nuts to remove inside the trunk 1 under the plastic trim on the edge of the trunk seal,its a real pain because the nuts are not real big. :D
Nov 20, 2007 at 5:41 AM
