1993 Ford Taurus Stalls After Running
JSSMITH
I have a 1993 ford Taurus, gl 3.8 liter v6. The car starts, and runs for a few minutes then boggs down and cuts off. The car will start about 2-3 minutes later, but I just end up going through the same process all over again. I tried just starting the car putting it in drive and going, but it justs boggs down and cuts off. When this first happen I was about 10 minutes from my house, so after severly failed attemps at getting the car to go. I let it sit for about 20 minutes, started the car and got it home with no problems. When I got the car home I let it run to see if the problem would start up again and it did. Can someone please tell me, whats going on with this car.
Apr 8, 2006 at 11:38 AM
PEPPERMRJ
  • 1,158 POSTS
Might need a tuneuip and a new fuel filter. Check for vacuum leaks. Engine light lit?
Good luck and let us know. :)
Apr 8, 2006 at 3:58 PM
Suggested Repair
Perform a tune-up, replace the fuel filter, check for vacuum leaks, and note whether the check engine light is on.
Conversation Summary
The owner of a 1993 Ford Taurus 3.8L says the engine starts, runs a few minutes, then bogs down and stalls. It restarts after a short wait and repeats the cycle; after sitting longer it drove home, then stalled again while running. The expert suggests a tune-up, a new fuel filter, a vacuum leak check, and asking whether the engine light is on.
