2000 Ford Taurus Slow Idle Stalls
KEVIN_H
2000 ford taurus 50000miles.Got a code and replaced EGR valve and bakepresure sensor.After replacing the parts ,engine idle speed gets slow and will stop sometime.No driving problem.scanned no code.
Aug 12, 2007 at 3:25 PM
  • 75,988 POSTS
[quote:bcf4395265="kevin_h"]2000 ford taurus 50000miles.Got a code and replaced EGR valve and bakepresure sensor.After replacing the parts ,engine idle speed gets slow and will stop sometime.No driving problem.scanned no code.[/quote:bcf4395265]
Check your ISC device-could also need a relearning procedures. ( Computer Relearn )
Aug 12, 2007 at 5:45 PM
Suggested Repair
Check the idle speed control (ISC) device and perform a computer relearn procedure.
Conversation Summary
The owner of a 2000 Ford Taurus with 50,000 miles replaced the EGR valve and backpressure sensor after a code. Afterward the engine idles slowly and sometimes stalls, with no driving problems and no stored codes. The expert suggests checking the idle speed control device and performing a computer relearn.
