2006 Ford Taurus Power Steering Overflow
DBERGERS
I have a privately owned bodyshop and have worked for gm dealers for25+ yrs. I have a 2006 ford taurus se 3.0L with 19,000 miles,that was in an accident. The power steering resevoir was damaged and all the fluid leaked out, I installed a new factory pump added fluid and started the car ,moved the steering wheel back and forth to bleed system, pump excessively noisey and when you turn the car off it overflows, thought it was a bad pump. returned it to ford got another one and guess what? Same problem. Knowbody at any of the local ford dealers seem to know what could be causing this problem Please help!
Dana
Feb 22, 2007 at 8:59 AM
CHEVY22
  • 1,375 POSTS
im wondering where the car was hit and if any of the p/s lines were pinched ?? check the fluid your using also the wrong fluid will cause the pump to be noisy , but still not make it pump back out , let me know on the damage point
Feb 22, 2007 at 10:35 AM
DBERGERS
Straight front end hit....checked all the lines for kinks nun found. (using ford fluid), after talking to a couple ford techs we are thinking that maybe some plastic from the reservoir was sucked into the system and partially plugged the inline filter so I guess I will have to replace the filter line and see how that works any other suggestions on this problem would be great and thanks so much for your reply.
Dana
Feb 22, 2007 at 2:15 PM
CHEVY22
  • 1,375 POSTS
no problem , and you know i didnt even think of that , i broke my rule , keep it simple
thanks
Feb 22, 2007 at 9:31 PM
Suggested Repair
Confirm the lines are not kinked and the correct Ford power steering fluid is used. Replace the power steering filter line, since debris from the damaged reservoir may be partially blocking the inline filter and causing pump noise and overflow after shutdown.
Conversation Summary
A 2006 Ford Taurus lost its power steering fluid after the reservoir was damaged in a straight front-end collision. Two new factory pumps were noisy and the reservoir overflowed after the engine was shut off, despite bleeding and using Ford fluid. The lines were checked and not kinked. The owner and Ford technicians suspected plastic debris had partially plugged the inline filter, and the expert agreed that replacing the filter line was the simple next step.
