I have a privately owned bodyshop and have worked for gm dealers for25+ yrs. I have a 2006 ford taurus se 3.0L with 19,000 miles,that was in an accident. The power steering resevoir was damaged and all the fluid leaked out, I installed a new factory pump added fluid and started the car ,moved the steering wheel back and forth to bleed system, pump excessively noisey and when you turn the car off it overflows, thought it was a bad pump. returned it to ford got another one and guess what? Same problem. Knowbody at any of the local ford dealers seem to know what could be causing this problem Please help!
Dana
Dana
Feb 22, 2007 at 8:59 AM
