Code p1400?
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
BBB86
Car runs like it's only firing 2 cylinders, replaced Diff pressure sensor, still running poorly. Any suggestions?
Nov 14, 2024 at 3:41 AM
  • 55,797 POSTS
So, I would check the engine compression first to see if the engine is hurt or not, you could upload a short video of the engine cranking from under the hood so I can tell what going on. I would not worry about this code right now.
P1400 - Differential Pressure Feedback Electronic (DPFE) Sensor Circuit Low Voltage Detected
We need more information to help but this will be a good start. Please go over this guide and get back to me:
Let us know what you find.
Nov 14, 2024 at 4:02 AM
